bmpcabin
Jul 31, 2025Guide
Cax80 Astound 1gig plan, intermittent downstream flashing led
Installed a cax80 on Astound/RCN. Ast made the changes, up and running but very frequent drops and dowmstream led flashing. Tech came, found many problems with cables from pole to modem. He changed e...
bmpcabin
Jul 31, 2025Guide
I assume you mean this...
Logs
- FURRYe38Jul 31, 2025Guru - Experienced User
This from from this location: https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
- bmpcabinJul 31, 2025Guide
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required ones.
4) Contact your service provider for troubleshooting help.Internet Access: Good
Downstream Status: Poor
Partial Service: Poor
Cable modem is in partial service mode. Your service provider might be under maintenance. Most of the time it won't affect your traffic and will automatically clear when work is complete.Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Thu Jul 31 17:15:34 2025Startup Procedure
Acquire Downstream Channel: 531 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Downstream Bonded Channels (Partial Service)
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 12 531000000 Hz -1.6 dBmV 40.6 dB 3 0
2 Locked 256 QAM 1 321000000 Hz 0.3 dBmV 41.6 dB 0 0
3 Locked 256 QAM 2 327000000 Hz 0.3 dBmV 41.5 dB 0 0
4 Locked 256 QAM 3 333000000 Hz 0.3 dBmV 41.4 dB 0 0
5 Locked 256 QAM 4 339000000 Hz 0.4 dBmV 41.1 dB 0 0
6 Locked 256 QAM 5 345000000 Hz 0.4 dBmV 41.4 dB 1 0
7 Locked 256 QAM 6 351000000 Hz 0.3 dBmV 41.1 dB 0 0
8 Locked 256 QAM 7 357000000 Hz 0.1 dBmV 41.1 dB 0 0
9 Locked 256 QAM 8 363000000 Hz 0.2 dBmV 40.8 dB 0 0
10 Locked 256 QAM 9 369000000 Hz 0 dBmV 40.8 dB 0 0
11 Locked 256 QAM 10 519000000 Hz -1.5 dBmV 40.8 dB 3 0
12 Locked 256 QAM 11 525000000 Hz -1.7 dBmV 40.8 dB 2 0
13 Locked 256 QAM 13 537000000 Hz -1.6 dBmV 40.4 dB 3 0
14 Locked 256 QAM 14 543000000 Hz -1.8 dBmV 40.9 dB 2 0
15 Locked 256 QAM 15 549000000 Hz -1.6 dBmV 41.1 dB 0 0
16 Locked 256 QAM 16 555000000 Hz -1.6 dBmV 40.8 dB 2 0
17 Locked 256 QAM 17 561000000 Hz -1.5 dBmV 41.1 dB 4 0
18 Locked 256 QAM 18 567000000 Hz -2 dBmV 41 dB 5 0
19 Locked 256 QAM 19 573000000 Hz -2.2 dBmV 41.1 dB 3 0
20 Locked 256 QAM 20 579000000 Hz -1.8 dBmV 41.3 dB 1 0
21 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
22 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
23 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
24 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
25 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
26 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
27 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
28 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
29 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
30 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
31 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
32 Not Locked Unknown 0 0 Hz 0.0 0.0 0 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 4 5120 Ksym/sec 36800000 Hz 40.5 dBmV
2 Locked ATDMA 5 5120 Ksym/sec 30350000 Hz 40.5 dBmV
3 Locked ATDMA 6 5120 Ksym/sec 23900000 Hz 40.0 dBmV
4 Not Locked Unknown 0 0 0 0.0
5 Not Locked Unknown 0 0 0 0.0
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 159 675000000 Hz -0.22 dBmV 39.1 dB 166 ~ 3929 4589087678 3285813660 232
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
1 Locked 3 ,4 ,9 ,10 ,11 ,12 ,13 8 5300000 Hz 38.5 dBmV
Event Log
Time Priority Description
Thu Jul 31 17:14:26 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:13:08 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:11:06 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:10:41 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:10:18 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:09:24 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:09:02 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:08:37 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:07:54 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:07:05 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:06:13 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:37 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:33 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:28 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:05:08 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:04:45 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:04:43 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:04:06 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:02:57 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:02:38 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:01:52 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:00:53 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:00:28 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:59:19 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:58:52 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:58:44 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:57:06 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:56:25 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:56:07 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:55:42 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:54:24 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:54:07 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:53:53 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:53:34 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:51:46 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:51:25 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:50:50 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:50:25 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 16:47:48 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1; - bmpcabinJul 31, 2025Guide
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
Current time: Thu Jul 31 17:56:16 2025Startup Procedure
1 Locked 256 QAM 12 531000000 Hz -1.4 dBmV 40.5 dB 3 0
2 Locked 256 QAM 1 321000000 Hz 0.4 dBmV 41.6 dB 0 0
3 Locked 256 QAM 2 327000000 Hz 0.4 dBmV 41.4 dB 0 0
4 Locked 256 QAM 3 333000000 Hz 0.5 dBmV 41.4 dB 0 0
5 Locked 256 QAM 4 339000000 Hz 0.5 dBmV 41.2 dB 0 0
6 Locked 256 QAM 5 345000000 Hz 0.5 dBmV 41.4 dB 1 0
7 Locked 256 QAM 6 351000000 Hz 0.5 dBmV 41.1 dB 0 0
8 Locked 256 QAM 7 357000000 Hz 0.2 dBmV 41 dB 2 0
9 Locked 256 QAM 8 363000000 Hz 0.3 dBmV 40.8 dB 0 0
10 Locked 256 QAM 9 369000000 Hz 0.2 dBmV 40.8 dB 0 0
11 Locked 256 QAM 10 519000000 Hz -1.3 dBmV 40.8 dB 3 0
12 Locked 256 QAM 11 525000000 Hz -1.5 dBmV 40.8 dB 2 0
13 Locked 256 QAM 13 537000000 Hz -1.3 dBmV 40.4 dB 3 0
14 Locked 256 QAM 14 543000000 Hz -1.6 dBmV 40.9 dB 2 0
15 Locked 256 QAM 15 549000000 Hz -1.4 dBmV 41.1 dB 0 0
16 Locked 256 QAM 16 555000000 Hz -1.4 dBmV 40.8 dB 2 0
17 Locked 256 QAM 17 561000000 Hz -1.2 dBmV 41 dB 4 0
18 Locked 256 QAM 18 567000000 Hz -1.8 dBmV 41 dB 5 0
19 Locked 256 QAM 19 573000000 Hz -2 dBmV 41.1 dB 3 0
20 Locked 256 QAM 20 579000000 Hz -1.6 dBmV 41.2 dB 1 0
1 Locked 0 ,1 ,2 ,3 159 675000000 Hz -0.12 dBmV 40.0 dB 166 ~ 3929 4813920790 3476292645 232
Event Log
Thu Jul 31 17:54:46 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:54:37 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:54:21 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:54:12 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:53:24 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:53:08 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:52:59 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:52:43 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:50:34 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:50:09 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:45:53 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:45:28 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:42:39 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:42:38 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:42:14 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:42:01 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:41:44 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:41:22 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:41:15 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:40:36 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:40:34 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:40:11 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:39:22 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:38:43 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:36:33 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:36:18 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:36:08 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:35:40 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:35:34 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:35:15 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:33:01 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:32:36 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:31:18 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:30:53 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:28:47 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:28:40 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:28:22 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:28:15 2025 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;
Thu Jul 31 17:24:12 2025 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=34:98:b5:d1:7e:d9;CMTS-MAC=2c:0b:e9:14:dd:5b;CM-QOS=1.1;CM-VER=3.1;- FURRYe38Jul 31, 2025Guru - Experienced User
What Firmware version is loaded on the CAX80?
I see this for sure: "
Cable modem is in partial service mode. Your service provider might be under maintenance. Most of the time it won't affect your traffic and will automatically clear when work is complete."Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
