Parmenedes's avatar
Mar 03, 2021
CAX80 (AX6000): multi-gig ethernet port and botched firmware update
OK, so it's possible that the info I'm working from here is incorrect, in which case, please politely correct me, but unless I'm wrong, the most recent firmware update for the CAX80 somehow screwed up the multi-gig ethernet port (i.e. the MOST important ethernet port on the modem/router).  The port was working fine until we updated to 2.1.1.4, at which point I keep getting inconsisten connections and full-blown disconnects.  I read that that was a result of a problem with that firmware (again, please correct me if I'm wrong).
But assuming this is correct, I'm wondering if there is a timeline for when this will be fixed.  I'm not even sure how much control we have over that firmware since it's pushed to us by comcast, so I'm not sure it's possible for us to revert to a previous version, and the problems with that port are kind of driving me nuts.  The obvious workaround is to plug my ethernet into one of the other ports, which I'm doing for now, but that means slower and less consistent speeds/latency, and it kind of defeats the purpose of having a $450 router in the first place - that was one of the cool selling points of this router in the first place.
Any help would be appreciated.
  • FURRYe38's avatar
    What is connected to the multi gig port? PC?
    Has a factory reset and setup from scratch been performed since last update?
    I hadn't seen any problems on this port after mine was updated...
      • FURRYe38's avatar
        Do any wired devices experience a problem here? And the other LAN ports work ok if you don't use the MG port?
        What is the mfr and model# of the wired adapter thats being used in the PC?
        When I had my CAX80 online, I had my Orbi AX router connected to the multi gig port and didn't see any issues. Is one devices that connects at 2.5Gb and worked with the CAX80.
