freddieb91
May 01, 2025Aspirant
Cax80 ethernet port went out
hello im having trouble with my cax80 this morning the t=ethernet ports just went out and ive done the soft reset hard reset and tried new cables but the only thing that is showing is the 2 port on the LEDS in the front but on showing in orange and then goes away and then goes back to orange has anyone seen this or have a solutions besides buying another one
what 2 leds on the front are doing that? There's multiple leds on it.
Usually if its the top 2, the top is power and the 2nd is downstream.
-the CAX is one of those routers that has to be connected back to the isp. If you turn it on and it doesn't detect a coax detection (downstream), it'll continue to cycle until it does. You might check with the ISP as that sounds like the issue
- freddieb91Aspirant
Ok. That helps. You're showing locked in. Can you access it via wifi?
Did you try other cables? And different devices?
How old is it?
What is connected to the LAN ports? Anything or are these coming on by themselves?
Have you tried a factory reset and setup from scratch with the ISP Coax cable disconnected from the modem at first then give a minute, reconnect it and walk thru the Setup wizard?
Try connecting any ethernet PC to each of the LAN ports to see the color behavior...
- freddieb91AspirantYes ive soft reset and hard reset
There are 2 cyptro miners that are connected i will plug my laptop up but I'm just going to grab and switch with 4 ports and us the ethernet from there if issue can't be resolved and the light for 2 port come on orange and turns off after a few sec and this is the only one that turns on and off but no data coming thru it
