Zythryn's avatar
Zythryn
Initiate
Sep 24, 2024
CAX80 LAN address keeps reverting to default 192.168.1.1
I've had this router configured and installed for over a year, with no issues, with a configured LAN address of 10.1.1.1.
This morning, I discovered the LAN address had reverted to 192.168.1.1.  This caused a number of issues for the network.
I attempted to change it back via the web browser interface.
Going to the Advanced tab, then Setup, then LAN Setup.
After changing the LAN IP address to 10.1.1.1 and clicking on Apply, the router rebooted.
The browser could no longer connect after the reboot.
I tried connecting to the 'old' LAN address (192.168.1.1) and that worked.
I am going to try a factory reboot, but has anyone run into anything like this?
Firmware 5.1.1.8
Windows 11, Edge browser
  • FURRYe38's avatar
    Can't say that I have, however last time I had my CAX80 online, I used 192.168.0.1 for it's address and it's always held.
    • Zythryn's avatar
      Zythryn
      Initiate
      Thanks, I also tried Chrome.
      Looks like a factory reset is in my future 😞
      • FURRYe38's avatar
        I always use MS Edge to configure mine.
