KWE325
Dec 04, 2023Aspirant
CAX80 loses 2.4 wifi band
This has happened to me twice in the last month - the 2.4 GHz WiFi band shows up as available, the light on the modem is lit but it cannot connect to anything, nor can anything connect to it. The ethernet and the 5 GHz WiFi band both remain fine and functional. A reboot corrects this issue.
Any ideas as to why this might be happening?
What devices do you have all connected?
What channel configurations are currently set on the router?
Is Smart Connect enabled on the modem?
Any Wifi Neighbors near by? If so, how many?- KWE325Aspirant
Firmware is v2.1.5.2
Connected devices include Roku TV, Amazon Echo, ring camera, MacBook Air laptop, Epson printer, iphones and a Galaxy tablet.
Channel for the 2.4 wireless is Auto (9).
SmartConnect is NOT enabled.
On any given day there is as many as 3 or 4 wifi neighbors.
Try setting manual channel 1, 6 or 11 on 2.4Ghz
Does the front LED on the modem for 2.4Ghz turn OFF when this happens?
