dbmdude
Aug 24, 2020Aspirant
CAX80 NightHawk AX8 Cable Modem Has no QoS settings
I cant select the proper model as mine is not in the list; nor can I select a location because there is NOT one for Nighthawk AX8 Cable Modem. Anyway is there any chance that the QoS settings can...
Sep 23, 2020Guru - Experienced User
"There was never actual QoS settings or feature (except Speedtest was labelled as QoS).
It was renamed to Speedtest in newer FW."
ktamas77 wrote:I'm also looking for the QoS option.
I used to have a RAX12 and it had QoS. Since in our new home we have Cable internet, we purchased the BEST Netgear Cable moden, the CAX80. And it doesn't have QoS? In the flagship cable router/modem of Netgear? This is ridiculous.
Without QoS, if we can't throttle upload speed, uploads are often failing/breaking/disconnecting.
Please add QoS to the CAX-80. Every single router has it. Otherwise we'll be forced to chose a different brand.
dbmdude
Sep 25, 2020Aspirant
I think the point ktamas77 and I are trying to make is that PEOPLE WANT QOS....
Seriously how hard is it to port code from a newer router over and make it work on this cablemode,/ router combination?????????????????????????
Seriously........
- FURRYe38Sep 26, 2020Guru - Experienced User
I would post about your request here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Maybe NG will relent and add it. Nothing we can do here in the forums.
Good Luck.
