CATAHA
Sep 08, 2025Tutor
CAX80 No internet via WIFi but no problem with RJ45
I have problem with both of my Netgear units. This morning i woke-up and my cellphone said no internet via wifi, I checked on computer with wire plug been connected directly to CAX80 and i have no ...
Sep 09, 2025Guru - Experienced User
Turn OFF Protection Engine on the CAX80s web page and see if this helps:
NETGEAR Nighthawk - Protection Engine Feature FAQ | NETGEAR Communities
What channels are you using on the CAX80? Try 1 or 11 on 2.4Ghz and 40 or 48 on 5Ghz.
Is FW updated on the EAX80?
What is distances between the CAX80 and EAX80? 30 feet is starting distance or more.
- 22morrowSep 09, 2025Initiate
Just wanted to say that I was having similar issues to OP with my CAX80 - woke up yesterday morning with no internet access on Wi-Fi OR Ethernet even though the connection status looked good in the modem dashboard. Called my ISP and everything looked good to them as well. After resetting the modem several times I was eventually able to get internet access through the Firefox browser but nothing else…which was super strange.
I disabled the Protection Engine feature like you suggested and it fixed everything! Now all my devices are connecting like normal. Thank you 🙏🏻
- AokaySep 09, 2025Aspirant
I had similar CAX80 issues. Hard wired devices worked fine, Wi-Fi devices could hook up to the router but had no internet access and nighthawk app wasn't working right either.
After multiple attempts to get the wi-fi working again, I ended up doing factory reset, uninstalled the nighthawk mobile app and started all over as if it was my initial set up of the router and the app. Everything is now up and running.
Unfortunately, this isn't the first time I've had to do this since purchasing the CAX80 in October of 2023. Very frustrating and I don't get why this happens periodically.
Another ongoing issue we've had is that our Wi-Fi continually connects and disconnects to our devices. Hoping it stays stable this time.
I came into this thread after reading about disabling the Protection Engine feature. Is that something I should check and do to prevent this from recurring?
- FURRYe38Sep 09, 2025Guru - Experienced User
- CATAHASep 10, 2025Tutor
It did not help
5.1.1.8
Channels have nothing to do with it.
2-10 feet
- FURRYe38Sep 10, 2025Guru - Experienced User
And you did disable Protection Engine?
Disable Smart Connect.
Try a Networking Reset on the phone. Not a full factory reset, just a networking reset. Check with the phone mfr on where this item will be located...
https://community.netgear.com/discussions/home-cable-modems-routers/cax80-no-internet-via-wifi-but-no-problem-with-rj45/2465314/replies/2465449
Yes on multiple Phones - NO Changes
