CATAHA
Sep 08, 2025Tutor
CAX80 No internet via WIFi but no problem with RJ45
I have problem with both of my Netgear units. This morning i woke-up and my cellphone said no internet via wifi, I checked on computer with wire plug been connected directly to CAX80 and i have no ...
Aokay
Sep 09, 2025Aspirant
I had similar CAX80 issues. Hard wired devices worked fine, Wi-Fi devices could hook up to the router but had no internet access and nighthawk app wasn't working right either.
After multiple attempts to get the wi-fi working again, I ended up doing factory reset, uninstalled the nighthawk mobile app and started all over as if it was my initial set up of the router and the app. Everything is now up and running.
Unfortunately, this isn't the first time I've had to do this since purchasing the CAX80 in October of 2023. Very frustrating and I don't get why this happens periodically.
Another ongoing issue we've had is that our Wi-Fi continually connects and disconnects to our devices. Hoping it stays stable this time.
I came into this thread after reading about disabling the Protection Engine feature. Is that something I should check and do to prevent this from recurring?
Sep 09, 2025Guru - Experienced User
