CATAHA
Sep 08, 2025Tutor
CAX80 No internet via WIFi but no problem with RJ45
I have problem with both of my Netgear units. This morning i woke-up and my cellphone said no internet via wifi, I checked on computer with wire plug been connected directly to CAX80 and i have no ...
CATAHA
Sep 10, 2025Tutor
It did not help
5.1.1.8
Channels have nothing to do with it.
2-10 feet
Sep 10, 2025Guru - Experienced User
And you did disable Protection Engine?
Disable Smart Connect.
Try a Networking Reset on the phone. Not a full factory reset, just a networking reset. Check with the phone mfr on where this item will be located...
