tequekama
Dec 22, 2025Aspirant
CAX80 Poor Cable Connection
I have a CAX80 with Spectrum internet, and I noted that the Cable Connection indicates a "Poor" Status and and downstream status indicates 11.0dBmV which appears to on the high side of the recommende...
Jan 15, 2026Guru - Experienced User
Any progress on this?
tequekama wrote:I have a CAX80 with Spectrum internet, and I noted that the Cable Connection indicates a "Poor" Status and and downstream status indicates 11.0dBmV which appears to on the high side of the recommended range. I have double/triple checked all cables inside the home, and have only not checked the outside connection into the house.
I still get decent/good speeds, but should it be a cause for concern?
