buddyb99's avatar
buddyb99
CAX80 poor network status and sometimes network dropped
Cannot solve poor cable connection. Below is the diagnostic.
Cable Connection
Cancel Apply
Cable Diagnostic
Status:   Poor
Action:
[Partial Service]
If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required ones.
4) Contact your service provider for troubleshooting help.
Internet Access:
Downstream Status:
Upstream Status:
Refresh Save Cable Diagnostic Info
Advanced Information
Frequency Start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
Procedure
Status
Comment
Acquire Downstream Channel
597 MHz
Locked
Connectivity State
OK
Operational
Boot State
OK
Operational
Security
Enabled
BPI+
Downstream Bonded Channels (Partial Service)
Channel
Lock Status
Modulation
Channel ID
Frequency
Power
SNR
Correctables
Uncorrectables
1
Locked
256 QAM
14
597000000 Hz
0.5 dBmV
40.6 dB
0
0
2
Locked
256 QAM
2
525000000 Hz
0.9 dBmV
40.1 dB
0
0
3
Locked
256 QAM
3
531000000 Hz
0.9 dBmV
40.2 dB
0
0
4
Locked
256 QAM
4
537000000 Hz
1.1 dBmV
40.5 dB
0
0
5
Locked
256 QAM
5
543000000 Hz
0.8 dBmV
40.5 dB
0
0
6
Locked
256 QAM
6
549000000 Hz
0.7 dBmV
40.6 dB
0
0
7
Locked
256 QAM
7
555000000 Hz
1.1 dBmV
40.7 dB
0
0
8
Locked
256 QAM
8
561000000 Hz
1.0 dBmV
39.2 dB
0
0
9
Locked
256 QAM
9
567000000 Hz
0.8 dBmV
40.9 dB
1
0
10
Locked
256 QAM
10
573000000 Hz
0.8 dBmV
40.5 dB
0
0
11
Locked
256 QAM
11
579000000 Hz
0.7 dBmV
40.8 dB
2
0
12
Locked
256 QAM
12
585000000 Hz
0.3 dBmV
40.8 dB
0
0
13
Locked
256 QAM
13
591000000 Hz
0.3 dBmV
40.7 dB
3
0
14
Locked
256 QAM
1
519000000 Hz
1.1 dBmV
39.9 dB
0
0
15
Locked
256 QAM
15
603000000 Hz
0.5 dBmV
40.6 dB
0
0
16
Locked
256 QAM
16
609000000 Hz
0.3 dBmV
40.5 dB
2
0
17
Locked
256 QAM
17
495000000 Hz
1.1 dBmV
39.4 dB
0
0
18
Locked
256 QAM
18
501000000 Hz
0.9 dBmV
39.4 dB
0
0
19
Locked
256 QAM
19
507000000 Hz
1.0 dBmV
39.6 dB
0
0
20
Locked
256 QAM
20
513000000 Hz
1.1 dBmV
39.7 dB
0
0
21
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
22
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
23
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
24
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
25
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
26
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
27
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
28
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
29
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
30
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
31
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
32
Not Locked
Unknown
0
0 Hz
0.0 dBmV
0.0 dB
0
0
Upstream Bonded Channels
Channel
Lock Status
US Channel Type
Channel ID
Symbol Rate
Frequency
Power
1
Locked
ATDMA
1
5120 Ksym/sec
36800000 Hz
38.0 dBmV
2
Locked
ATDMA
2
5120 Ksym/sec
30350000 Hz
37.3 dBmV
3
Locked
ATDMA
3
5120 Ksym/sec
23900000 Hz
36.5 dBmV
4
Not Locked
Unknown
0
0
0
0.0 dBmV
5
Not Locked
Unknown
0
0
0
0.0 dBmV
6
Not Locked
Unknown
0
0
0
0.0 dBmV
7
Not Locked
Unknown
0
0
0
0.0 dBmV
8
Not Locked
Unknown
0
0
0
0.0 dBmV
Downstream OFDM Channels
Channel
Lock
Status
Modulation /
Profile ID
Channel
ID
Frequency
Power
SNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1
Locked
0 ,1 ,2 ,3
159
651000000 Hz
1.48 dBmV
38.4 dB
646 ~ 3449
72535164
72465703
0
2
Not Locked
0
0
0 Hz
0 dBmV
0 dB
0 ~ 4095
0
0
0
Upstream OFDMA Channels
Channel
Lock Status
Modulation / Profile ID
Channel ID
Frequency
Power
1
Not Locked
0
0
0 Hz
0 dBmV
2
Not Locked
0
0
0 Hz
0 dBmV
Extended Upstream Transmit Power
Enable Extended Upstream Transmit Power
Current System Time:Mon Apr 04 19:04:58 2022
System Up Time:00:22:11
  • plemans's avatar
    You have a lot of unlocked channels. And your upstream power isn't in line with where it should be in comparison to your downstream values.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
    • buddyb99's avatar
      buddyb99
      Thanks Plemans, My gateway is connected directly to the coaxial cable coming from the box outside my building and I don't have any amplifiers, signal attenuators, or splitters from the coax. I've had RCN come out and check the line from outside up to my gateway and they cannot find any issues with the line (of course they are not well trained). I'm really stumped as to what the issue could be. Any other ideas or tests I can run?
      • plemans's avatar
        Are you having issues with your connection other than the unlocked channels?
        Is it dropping?
