Archers
Dec 07, 2021Tutor
CAX80 seeming firmware issues
I have been struggling with my Nighthawk CAX80 and driven up the wall with Netgear's technical support that just wants to shove their premium paid support down your throat without considering that th...
Archers
Dec 07, 2021Tutor
Good day, thanks for the prompt response.
What Firmware version is currently loaded? As of this morning I was forced to "upgrade" to V2.1.3.5 again through the Nighthawk app. When this issue started yesterday my modem was auto updated to the latest version, I downgraded to 2.1.1.4, back to 2.1.3.5 (forced), 2.1.2.6, back to 2.1.3.5 (forced), 2.1.1.4 again and then the latest again this morning. Update - back to 2.1.1.4
After loading FW, did you factory reset by using the ERASE button on the CAX web page or the reset button in back? I originally didn't factory reset until I tried everything else I could think of, but then I used the reset button. After seemingly no effect the reset on the software page, after seemingly no effect the 30-30-30 reset, after no effect a 60-60-60 reset.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Checked again this morning, all good
Be sure the ISP provisions the modem correctly. Reprovisioned this morning, no change
Be sure there are no coax cable line splitters in the between the modem and ISP service box. No Splitters
Be sure your using good quality RG6 coax cable up to the modem. Indeed
Be sure to power OFF the modem for 1 minute then back ON. Did this, also at one point unplugged for 30+ minuetes
Is there any way to get a hold of technical support to resolve or to get an older firmware version
Regards
Dec 07, 2021Guru - Experienced User
Open up a support ticket and let NG support know whats going on:
https://www.netgear.com/support/#
https://my.netgear.com/support/contact.aspx
Good Luck.
- ArchersDec 07, 2021Tutor
Thank you, I created a ticket with them last night but they won't do a think unless I authorize a payment of I believe $60
