jcomey
Nov 28, 2022Aspirant
CAX80 Shows Active Connection, But No WiFi Available
Hi, I'm with Cox (it's the only available option where I live, sigh), and I've had two issues with my CAX80. 1) The WiFi was available on only the 2.4ghz band (the 5ghz band would show, but noth...
jcomey
I am not at home, so I'll give you what I've got via Anywhere Access.
FW: 2.1.4.2
SC: Not activated
Neighbors: Yes. Unsure of how many connections, but I'll say several.
AX + OFDMA = Unsure, but will check when I get home. Can you tell me if they should or should not be activated?
I will work through the rest when I get home (unfortunately, in several hours, am US EST). I appreciate the quick response, and will update when I have that additional information.
Nov 28, 2022Guru - Experienced User
Sounds good.
FYI, there is a newer FW version available:
