LucianD
Jul 11, 2022Tutor
CAX80 show's NOW Only Power LED on
Hello all, I have a CAX80 that has only the power LED light on. Resets do not work and unable to access the unit at all to attempt a firmware load. Suspect hardware issue. Netgear will not allow me t...
- Jul 12, 2022
Just wondering. If you disconnect the modem from the ISP coax line and pull the power adapter from the wall out let for 1 minute then plug back in with out connecting the modem to the ISP coax line, does the modem front LEDs change behavior at all?
Jul 11, 2022Guru - Experienced User
- LucianDJul 11, 2022Tutor
Thanks for reply, but is there a solution to this issue?
- plemansJul 11, 2022Guru - Experienced User
LucianD If you read in the link, you're supposed to send your info via private message to one of the mod's listed. They might be able to help since you're out of your warranty period.
- LucianDJul 12, 2022Tutor
Thank you...I did send them messages on 7/8, but so far no response back. Such an unpleasant surprise for a this expensive piece of equipment to suddenly be non operational just a few months after the warranty expiration date.
I am hoping something can be done. đĄ
