LucianD's avatar
LucianD
Tutor
Jul 11, 2022
CAX80 show's NOW Only Power LED on
Hello all, I have a CAX80 that has only the power LED light on. Resets do not work and unable to access the unit at all to attempt a firmware load. Suspect hardware issue. Netgear will not allow me t...
  • FURRYe38's avatar
    Just wondering. If you disconnect the modem from the ISP coax line and pull the power adapter from the wall out let for 1 minute then plug back in with out connecting the modem to the ISP coax line, does the modem front LEDs change behavior at all?
