bl1085
May 07, 2026Guide
CAX80 wifi occasionally hangs
I have had a CAX80 for several years, generally very good. Perhaps once a month the wifi stops working. The RJ45 connections still work fine. I power cycle the CAX80 and all works again for ...
May 08, 2026Guru - Experienced User
Next time it goes down, a few things to try.
- log into it with a wired device. Check the logs/event logs. See if there's anything it shows
- Check if its both 2.4ghz and 5ghz or just one of them.
- If its both, try changing a channel to see if it fixes it.
