Retired_Member's avatar
Retired_Member
Aug 03, 2022
CAX80 Wireless mode settings
Greetings,
CAX80, why is the wireless setting 2.4 GHz mode set to 600Mbps? Can I change the mode? The wireless in setup mode is set as up to 1200 Mbps.
Thanks, Louf
  • FURRYe38's avatar
    What browser are you using?
    Is Smart Connect enabled? Try disabling SC?
    • Retired_Member's avatar
      Retired_Member
      Thanks FURRYe38, Firmware V2.1.3.7 and Firefox 103.0.1 64bit. I'll try disabling SC. Regards, Louf
