Moocow1980's avatar
Moocow1980
Apprentice
Dec 04, 2021
CAX80 won't work at all on WOW Internet; firmware update ruined it
Here's the deal.
I just got in the mail today a replacement from Netgear for my CAX80. (Hindsight says I may not have needed it, but here we are.)
I am with WOW Internet as my ISP in Columbus, OH.
The issue began around mid-November 2021, which based on sniffing around this forum, was the time frame a new firmware update was pushed and caused issues. That led to getting the aforementioned warranty replacement.
My old modem works. It's not my wiring. But the CAX80, it won't receive Internet. If I try to even do a hardwired local connection, I can't do any connections, even router login dot net, or the 192 168 1 1 address or anything. So if I wanted to manually update firmware or roll back, I can't. It will not connect.
I have done the 30-30-30 hard reset with the unit. I have called WOW, and they can't figure it out, no matter what we do.
I can't return the modem to Best Buy as the window passed. I'm not paying for extended warranty assistance with Netgear -- I had to PAY to ship my old unit for the replacement, which is insane and flat out robbery after I paid $450-plus for the unit or whatever it goes for. (Can't even spring for the prepaid label to a customer.) And if WOW can't do anything... I've PAID FOR AN EXPENSIVE BRICK BECAUSE OF THE FIRMWARE UPDATE!
I am extremely frustrated and extremely disappointed. Thanks for ruining my purchase, Netgear.
  • My CAX80 is 54 weeks old (siiiigh) and it's bricked this week. I am also told that there was an update done yesterday on WOW which is when my service quit working (in Mid Michigan). Have done soft, hard, factory resets, have requested a signal refresh. Nothing changes. Intermittently the wifi lights will not even light up. So now it fails the setup test (low signal) and we have not had any changes to a fairly new wire run and I've confirmed my coax cable is finger-tight, not damaged through the basement, etc. We have had some high winds so the other real possibility is some damage (even hyper local damage) to the lines. But I am concerned because I can't even get the CAX80 to talk to the setup wizard. When connecting a computer via ethernet it says "no internet." Grrrr.
    What else are we running on WOW successfully, and what are we expecting them to do (like send a new firmware update)? I don't have a lot of good ISP choices where we live. I'm highly annoyed to have to think about buying another router so soon. But staying dead in the water isn't a choice here either. (Nor is boosting the phone hotspot data every day thinking this is temporary.....)
    • FizzyOtter's avatar
      FizzyOtter
      Tutor
      I take it this issue is still going on with WoW.
      I've been having the exact same issue with the CAX80 with WOW. Unable to access routerlogin or the 192 168 1 1
      No gateway address. Can't access with the nighthawk app. Just a big ole paperweight.
      Was on the phone for an hour with Wow and they were telling me to call Netgear, and had Netgear tell me that its WoWs issue.
    • Jinguni's avatar
      Jinguni
      Guide
      I've been using the CAX30 / CAX30S with WOW's service, no issues after 4 months. Fortunately I was able to return the CAX80 I initially purchased.
        FizzyOtter
        Tutor
        I might just turn in my CAX80 for a CAX30S
        I've basically been playing phone tag and had both WOW and Netgear pointing fingers at each other, and seeing folks having no issues with the CAX30S I might switch to that.
        I mean I have to work and need a modem.
    • Basha94's avatar
      Basha94
      Guide
      I can say that my CAX80 has been up and running with absolutely no issues after switching providers (wow to spectrum).
      • wziemer's avatar
        wziemer
        Star
        I went through some alternative Netgear channels and was able to work with an engineer from Jan to May of this year and in May, they were able to work with WOW to determine the issue and roll out the fix after I loaded several engineering firmware to gather additional debug info and provide that data back to them. It was my understanding that this fix was rolled out to all CAX80 devices, but of course I have no way of validating that. That said, I can say that I'm a WOW customer that was transitioned over to Astound and I've had 0 issues with my CAX80 since, but I also run only in modem mode (router mode = no) at this time and have no interest in switching over to Router mode = yes for the foreseeable future, so I don't think I'm a very good case to validate if this is or is not working on Astound.
    • Jinguni's avatar
      Jinguni
      Guide
      I switched ISP from WOW/Astound to Xfinity, got tired of hassling with WOW since they couldn’t identify issue or provide workaround. They had me swap out 3 modems and issue still persisted. No issues occurred with Xfinity.
      • ChiFast's avatar
        ChiFast
        Guide
        The issue has been resolved for me and the CAX80 is working but I've been switched to Astound RCN because they acquired WOW customers in this area.
