Creekeris01's avatar
Creekeris01
cax80
Unexplained overnight crash, won't reset or connect to cable, modem can't be found. Is it an old W7 computer update failure causing this?
  • plemans's avatar
     What are the leds on the cax80 doing? (blinking, solid, color, etc for each one)
  • I get lights that eventually go all solid after an brief re-start, as is evidenced by the display of my NEST Digital Assistant beside it, as well as notification tones on household tablets and phones. It appears that for about 5 seconds I get internet, then zip.
    I am unable to access the setup, either thru the app or a desktop, desktop does not connect at all to "routerlogin" and the app information seems inaccurate and sporadic, continuously indicates "cannot connect" or "not found". Various attempts at Factory re-set (while powered, or from powered off) was useless, re-set did nothing, not even re-set the wifi name.
    I suspect this year-old "Rental Money saver" is now a "High priced Paper weight", but am hoping I am wrong.
    • FURRYe38's avatar
      https://community.netgear.com/t5/Cable-Modems-Routers/NOTICE-Users-with-sudden-non-functioning-CAX80-modems/td-p/2234550/jump-to/first-unread-message
    • olympos1625's avatar
      olympos1625
      NETGEAR Employee Retired
      Hi Creekeris01,
      We are sorry to hear about your experience with the modem. Please DM the following information:
      Name:
      Email:
      Phone:
      Preferred schedule (at least 2 days ahead)
      Timezone:
      Device S/N:
      Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
      I am looking forward to your response.
      Oliver
      Community Team
