JasonM2610's avatar
JasonM2610
Follower
Jan 23, 2025
CBR40 connected to T-mobile gateway through MoCA adaptor
I have a T-mobile wifi gateway device for my house that only has ethernet connections. Can I connect my Orbi CBR40 with coax input to my existing gateway via ethernet through a MoCA adaptor?
  • FURRYe38's avatar
    No. The modem side of the CBR is looking for Cable DOCSIS protocols from the ISP to connect to and associate too. Requirement for CBR gateways.
  • plemans's avatar
    but you could probably pickup a cheap RBR40 or RBR50 to replace it for one without coax. Since its an older system, plenty of them on the local facebook or ebay.
  • FURRYe38's avatar
    You can configure the CBR for a faux AP mode if your still wanting to use the wifi portion of the CBR and RBS.
