szcott
Dec 01, 2018Aspirant
Century Link
does this ac1750 work with CL Fiber internet
DarrenM
Dec 03, 2018Sr. NETGEAR Moderator
You would have to check with your ISP for supported modems.
DarrenM
antinode
Dec 03, 2018Guru
"CL Fiber internet" could mean more than one thing, including a
simple-looking Ethernet port, in which case, there would be no modem.
Or, it could mean some kind of DSL link to the premises.
If all you need is a router, then an R6300v2 should work. If you
need a modem, then you'd need a modem. Ask CenturyLink what you need,
or what they'd like to sell/rent you.
