Gregfox1
Mar 17, 2016Aspirant
CG 3000 ST AUS can two Routers with separate users access each other's Wi-Fi
Hello just wondering CG 3000 version 2 AUS unknown Netgear ADSL router same premises different users can one access the other Wi-Fi using the genie is it possible. I have one desktop also my laptop l...
DarrenM
Mar 21, 2016Sr. NETGEAR Moderator
Hello Gregfox1
Once you connect to the router you can access it via the genie.
DarrenM
Gregfox1
Mar 25, 2016Aspirant
Yes, I do realise once the genie is connected to your own router is a reset password is an check on traffic. My main question was to different type of Routers different users can my CG 3000 get past all the password and change the settings using their own genie? I'm a little bit paranoid because my old CG 3000 was hacked. I could not get back in an either could get this technical staff spent five hours one day in the end sent out Optus technician to install a new one.
- DarrenMMar 29, 2016Sr. NETGEAR Moderator
Gregfox1
Yea the only way they could get into your router is if they get your wireless password or they can physically connect to the modem itself.
DarrenM
