James_u_m's avatar
James_u_m
Cg 3100 d Router setup
I purchased a cg3100d few months ago & did not use it till last week. I tried 2 use it as wireless router. I connected the the internet source 2 Netgear (NG) WAN port. The led indicator on NG was lit. However there was no internet connection caming out fron any of the NG LAN port /transmitted wirelessly. (Router was set to Ipv 4 only & WAN was enabled). Please advise
  • Review the installation guide and user manualsl for setup information and use.
    Try a factory reset as well.
    Be sure your ISP supports this modem on there network.
  • FURRYe38's avatar
    • James_u_m's avatar
      James_u_m
      Thanks for your reply. I did a factory reset & still didnot work. I dont use the modem port of cg3100d. I use standard cable modem provided by my isp provider. At present I use other brand wireless router & works fine.
      • FURRYe38's avatar
        Possible your modem/router if faulty or bad.
