OlaWetterling
Mar 27, 2017Aspirant
CG2000-1TDNDS How do I set up?
How do I set up and get connected? Is there a manual to download?
DarrenM
Mar 29, 2017Sr. NETGEAR Moderator
Hello Olawetterling
Are you talking about the CG3000? did you but this modem or get it from your ISP?
DarrenM
OlaWetterling
Mar 30, 2017Aspirant
Thanks for your reply, Darren!
I've got it from my internet provider (yousee, Denmark). For use with thei cable network in the building. Used coax connection. Is that's why? And would it work if I reste the router to "factory mode"? And then - how do I set it up?....
- DarrenMMar 30, 2017Sr. NETGEAR Moderator
Hello OlaWetterling
Yea you could try to factory reset the unit by holding the the reset button for 10 seconds. But you may need to contact your ISP.
DarrenM
