Jostalli's avatar
Jostalli
Follower
Nov 16, 2017
CG3000D will reset but network remains password protected
I bought this router used and pushed the factory reset button when I plugged it in. It shows factory SSID but it’s password protected! I can not login to my network to make changes. I then held the factory reset button for 30 seconds and then disconnected power and plugged back in and my SSID is now 000000 still password protected. Help!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you able to plug a PC in via Ethernet and then configure the settings?
    DarrenM
