bilmar's avatar
bilmar
CG3000DV2 Cable Gateway will not connect to Roku Wirelessly
Just got this today from Amazon. Setup was easy and got it online with Brighthouse. Wifi works fine with Laptop, tablet etc but Roku fails on third step:
Connect to Wireless - OK
Connect to LAN - OK
Connect to Internet - FAIL error 009 ( DNS)
If I use an ethernet cable it works fine so DNS is ok
If I connect my old WiFi router  downstream of the new one  the Roku can connect fully to that router's SSID
So it appears that there is something going wrong in the  Netgear- Roku handshake but just for this router.
Any ideas?
  • Unfortunately no, Wifi on Roku is simply choose SSID and enter password - no options for DNS
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello bilmar
    Are you able to enter DNS settings into the roku if so try to use googles opens DNS which is 8.8.8.8 and 8.8.4.4 see if that works.
    DarrenM
