B_west53
Oct 19, 2016Initiate
Cg3000dv2 is dropping wifi
Anytime I want to use wifi I have to go reset my router. And say I use my iPad for 5 minutes and put it down my network is undetectable . I've seen so many threads about this issue. I contacted my in...
- Nov 04, 2016
Sorry to hear MD585 did not seem to help you. Your event log dump looks a lot like mine. I am not to savy with modems and routers and all the lingo so I cannot analyze it, I had the same critical 3, warnings 5 and error 4's. My background is large main frame design and test and thats been a while. May make me knowledgable enough to be dangerousas as they say.
Anyway, I am now post 72 hrs without any additional wifi drops. So I believe I am good. My sister reports that she is still good after 2 days.
Not saying you did not, not saying your problem is the same as mine, just ensure you follow the procedure, and I do not know if it all matters one way or the other, I just did exactly what netgear support instructed me to do:
Remove the ISP cable, then the power cord, reinstall the cable, then the power cord and I pressed and held the reset button for 40+ seconds. (He said 30 seconds)
During trouble shooting, we had changed several values (frag length, changed the channel number to 9 vs being auto). After the reset all were returned to the original values thus I assumed it had worked. Like I said, no more drops in 3 days. I did call time warner cable to alert them.
Retired_Member
Oct 25, 2016Since their firmware update, I have connectivity issues, WiFi Issues, and I cannot even access the admin page anymore and NO support because I'm beyond the support date unless I want to pay for it. I will not buy another Netgear product again
- jjk94Oct 27, 2016Guide
Dont have an answer for you but I believe I have problems since an update. What ISP are you using? How do you know that it was updated. Mine mysteriously now has a Genie Interface
- pisseduserOct 28, 2016Aspirant
i'm having the same issue on Time warner, which is now spectrum. it's ever since there was a firmware update
- jjk94Oct 28, 2016Guide
Does everybody now have a new interface since an update?. Im pretty sure I never had a guest network which I do now, As well as my Wifi password is scrolling accross those nice new Icons
mine upgraded to netgear genie, it was a much simpler interface before. now it's laggy as hell and very graphic. Also it updated my firmware to version V3.01.06 which according to this is for comcast internet not for my provider
