B_west53
Oct 20, 2016Initiate
Cg3000dv2 is dropping wifi
Anytime I want to use wifi I have to go reset my router. And say I use my iPad for 5 minutes and put it down my network is undetectable . I've seen so many threads about this issue. I contacted my in...
- Nov 04, 2016
Sorry to hear MD585 did not seem to help you. Your event log dump looks a lot like mine. I am not to savy with modems and routers and all the lingo so I cannot analyze it, I had the same critical 3, warnings 5 and error 4's. My background is large main frame design and test and thats been a while. May make me knowledgable enough to be dangerousas as they say.
Anyway, I am now post 72 hrs without any additional wifi drops. So I believe I am good. My sister reports that she is still good after 2 days.
Not saying you did not, not saying your problem is the same as mine, just ensure you follow the procedure, and I do not know if it all matters one way or the other, I just did exactly what netgear support instructed me to do:
Remove the ISP cable, then the power cord, reinstall the cable, then the power cord and I pressed and held the reset button for 40+ seconds. (He said 30 seconds)
During trouble shooting, we had changed several values (frag length, changed the channel number to 9 vs being auto). After the reset all were returned to the original values thus I assumed it had worked. Like I said, no more drops in 3 days. I did call time warner cable to alert them.
RSS3
Nov 01, 2016Tutor
I started having the same problem along with my sister about Wednesday Oct 26,2016 as well. We are both Time Warner customers. I am NOT out of free support and have been working with netgear support. Since discovering this forum and finding a bunch of folks are having the same problem, I have updated my case pointing the rep to this forum and that there own site (http://kb.netgear.com/app/answers/detail/a_id/25477/~/current-firmware-version-for-netgear-cable-modem-routers)
says V1.01.05 be it probably not updated as it should be. I am currently awaiting his response. OK, will try to send again. Lost connection while typing.
RSS3
Nov 02, 2016Tutor
OK, 24 hrs have passed since I did the following procedure given to me by the netgear support person. I have not had any additional problems. I updated him with the same news but told him I would not close the case for another day or 2 to be sure it resolves the problem. I will update here as well. I am also going to call time warner cable since they, I am sure, are getting complaints. From what I saw, I believe this firmware update V3.01.06 went across other models as well. Being different models I do not know if it effected them the same way. My reset hole is not red but it is just above the cable connection. ANyway, here is the procedure the support person gave me copy and pasted:
After reviewing the information you provided, I have a better understanding of your issue and believe I can resolve this for you. Please follow the steps below:
1.Please Remove the co-axial cable from the modem and turn off the modem and once again connect the co-axial cable back to the modem and check please.
Please follow the below steps to Hard reset the modem:
1.Please flip your device and locate the Restore factory settings red pin hole.
2.Make use of a paper clip or small pin and hold it down for 30 seconds when the device is switched on.
3.When you perform the Reset process, the power light would start to flash
4.please do reset when the device is powered on.
- MD585Nov 03, 2016Guide
I just tried that... 2 minutes after factory re-setting the modem and restarting, I was logging in and... the WiFi went down again, and needed to be unplugged.
2016-11-03, 12:18:55.0 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.1;CM-VER=3.0; 2016-11-03, 12:18:55.0 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.1;CM-VER=3.0; 2016-11-03, 12:17:59.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.1;CM-VER=3.0; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.0;CM-VER=3.0; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:01:00:01:00:01;CM-QOS=1.0;CM-VER=3.0; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Time Not Established Notice (6) WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INIT Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=00:00:00:00:00:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Modem: n450
ISP: TWC
- RSS3Nov 04, 2016Tutor
- computeringNov 04, 2016Initiate
I just want to thank RSS3 for being a Great Samaritan; I've also had this router problem, and your fix... fixed it. There are a few other threads about this same situation on the Netgear forum, and they don't seem to be aware of the fix.
Anyway, thanks for posting your fix in this forum. I truly didn't want to have to pay the outrageous fee just to talk to a Netgear representative about what they screwed up in the first place. Netgear should have posted this fix from the start.
