Retired_Member
Jul 16, 2016CG3000Dv2 (N450) Router 2 in 1 Lag Spikes HUGE
So,what happened is that I got a new router and I do some online gaming such as agar.io , slither.io , and diep.io.I think it has something to do with the ping.I have not tried anything yet but I have found another post and I didnt understand what the guy did so yeah.I havent touched anything in the router settings and I really need help as soon as possible.Thanks :) btw my model is CG3000Dv2 i do not have wired connections only wifi :)
- Retired_Member
If your ISP supplied the CG3000Dv2 contact them directly.
- Retired_Member
no my isp didnt give me the router :(
- DarrenMSr. NETGEAR Moderator
Hello BeastWolfYT
I would try to adjust the wireless channel to get a better connection you may also want to look and see if you need to do any port forwarding for those games.
DarrenM
