Mezzy's avatar
Mezzy
CG3000DV2 n450 unable to access WMM and thus QoS
So I am trying to divy up the bandwidth of the apartment because my one housemate loves to stream all day and night.
Anywho, I have the n450 wireless modem router and comcast as a provider. I log in and where the QoS setup tab should be, is nothing. I figure maybe I don't have WMM enabled, but the tab for that isn't there either... firmware is fine and I've tried different browers and the whole nine yards. There is just nothing there. I'm not even sure what I should do? And it's been over 90 days, so I don't want to have to pay to call support. thanks anyone!
EDIT: I did check the manual and it has it should be able to do it
  • Hello everyone
    WMM settings can be found under Advanced - Advanced Setup - Wireless Settings - WMM. Full QoS is not supported on cable products. We are having the User manual updated to show this.
    DarrenM
  • I can attest to this.  I do not have this option either.
    I'm trying to WFH this week and I cannot prioritise my wi-fi for my VPN
    • Mezzy's avatar
      Mezzy
      Yeah that's exactly what I have. It just isn't there.
      And while I'm glad it isn't just me, I'm also sorry you're dealing with it too.
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello everyone
        DarrenM
