goodmen116's avatar
goodmen116
CG3000v2 network priority control
Hi there,
I was wondering if anyone knows how to set up network priority on a CG3000v2 router. While I can find broadband control it is only for the entire router and not specific devices. My router is not similar to other routers as there is no option to set up a rule in the QoS setup. Any help would be appreciated greatly.
  • Looks like this maybe a ISP provided modem. I see no user manual for it. Only a QIG. There is something about optus.com.au there.
    I would contact your ISP for additional help and information about this.
  • FURRYe38's avatar
    • goodmen116's avatar
      goodmen116
      Thanks, you are correct it is a replacement modem given after our last one was damaged during a thunderstorm. This may explain the lack of features. I will contact my ISP.
      Thanks for your help
