LanceHall01
Sep 02, 2016Follower
CG4500BD seemingly will not boot or fails boot startup
I just obtained a CG4500BD/N900 cable modem/WIFI Gateway. When I plug in the power, all the LEDs initially light but eventually the following LEDs are flashing as a group about once a second: WPS(gre...
DarrenM
Sep 07, 2016Sr. NETGEAR Moderator
Hello LanceHall01
If the power is flashing red then there seems to be a issue with the modem it seems to be locked up I would contact support if the modem is still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
