ghaz
Jan 07, 2017Follower
CGD24N v2 how to make it as a repeater
CGD24N v2 how to make it as a repeater thanks
michaelkenward
Jan 08, 2017Guru - Experienced User
Are you sure that is the correct Model NUmber?
It doesn't appear here:
Do you mean this?
CGD24G | Product | Support | NETGEAR
Or do you have something that Netgear hand knitted for your ISP?
Very few modems and routers can work as wifi repeaters. Access point operation is more common.
