rpahule's avatar
rpahule
Follower
Jan 14, 2019
Change C7000 from router mode to cable modem mode
I have a C7000 V2 that I would like to setup in Bridge mode so I can install a new firewall and router in place of using the existing built in router features.  Is this device capable of being setup in that way? If so how would I go about completeing that task?  I do not want to set it up in a way that it would be double natting on the network.
Thank you.
1 Reply
  • > [...] Is this device capable of being setup in that way? If so how
    > would I go about completeing that task? [...]
       Did you consider looking at the manual?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "bridge mode"?
