Buju22
Sep 28, 2015Follower
Change DNS info for ?N450
How do you change the Primary and Secondary DNS for a Netgear n450? Once I log into the Netgear Gateway and click on Basic Settings, I can't click on anything to modify the DNS. Help!
Hanco
Feb 08, 2016Aspirant
What is the answer please?
I'm really disappointed as it does seem to be impossible. Is there a "fix" and a way to do the change? Or is this for some odd reason limited to one setting??
DarrenM
Feb 09, 2016Sr. NETGEAR Moderator
Hanco
This modem does not allow this setting to be changed. The Isp would push the DNS settings to the modem.
DarrenM
