crudolphy's avatar
crudolphy
change router to modem
I am receiving a "double NAT" error. I wish to change my router to be a modem only but cannot find instructions. The instructions posted on this website do not work. These instructions indicate there is a switch in Net Genie app. But this switch does not appear in the latest version of NetGenie that I just downloaded. Is there a way to match the cage to  modem only? Thank you.
  • > [...] I wish to change my router to be a modem only but cannot find
    > instructions. [...]
       Has your "my router" a maker and model number?
    > Model: WNDR3700v4|N600 Wireless Dual Band Gigabit Router
       That's a router, not a modem+router.  Is that what you have?  To what
    is it connected?  Is there some kind of modem involved?
       Strictly speaking, you can'y change a router into a modem.  You can
    usually change a modem+router into a modem.  In some cases, you can
    change a modem+router into a router.
       There are many "instructions posted on this website".  The
    non-psychics in your audience may not be able to guess what you've been
    reading.  Or doing.  Or what happened when you did whatever you did.
    • crudolphy's avatar
      crudolphy
      Thanks for the response. I am receiving an error saying I have a "double NAT issue". After reading an article about double NAT, I thought I needed to change my router/modem to be a modem only. I did not realize that my device WNDR3700 was a router only. So that will not fix my issue. I will have to try something else. Thank you for the prompt response. It has helped me refocus my efforts.
      • antinode's avatar
        antinode
        Guru
        > [...] I will have to try something else. [...]
           As a start, you might try answering the pending questions about your
        equipment.  For example:
        > [...] To what is it connected?  Is there some kind of modem involved?
