Aussie123
Feb 28, 2019Aspirant
Changeover from CG3100D BPAUS form copper to optic fibre
I have been using the CG3100D 2BPAUS for sometime, and the modem has been excellent, as Wi Fi is disabled.
I suffer a central nervous system disorder, which makes very will when I exposed to wi...
antinode
Mar 01, 2019Guru
> [...] I can't have any wireless in my home. [...]
Sounds to me like pseudo-science, but I assume that any discussion on
that topic would be pointless. (And in which, I won't participate
here.)
> [...] I must have their modem [...]
Which is a what, exactly?
> I can't understand why the provider is bullying me [...]
Perhaps because they have no equipment to offer which would be
acceptable to you. (Which would be quite reasonable, if the equipment
which they do offer presents no actual hazard.)
If I believed that the EM radiation from a typical wireless router
presented some actual hazard (which I do not), and that was the only
device type which my ISP supported, then I might visit my local hardware
store, buy enough aluminum window screening to construct a Faraday cage
around my "dangerous" gizmo, and surround my "dangerous" gizmo with this
"protective" device. I calculate the wavelength at 5GHz to be about
6cm, which is much larger than typical window-screen mesh, so it should
be (physically, if not psychologically) effective.
Or, as a quick Web search for terms like, say:
shielding wireless router
suggests, there are commercially produced (often overpriced) shielding
devices available in abundance, for the protection of the gullible (from
everything but themselves).
Then I'd start to worry about the radiation from the Ethernet cables
which are still in use.
- Aussie123Mar 02, 2019Aspirant
My original posting for help and compassion was written under stress and duress and I was having a meltdown and couldn’t get my words together. I had been searching for a safe modem to replace my Netgear CG3100D. I just read what I posted and I could see I was having a bad time with my illness (peripheral neuropathy and distal myopathy) while writing the posting above.
I am an 82-year old ex-military, ex-Vietnam veteran and my illness was caused by working long-term and prolonged periods in the military communications network and all the other crap I was exposed to in Vietnam. I got rejected when I returned from Vietnam and it really craps me off when I still endure rejection from your criticism and belittling.
I know my posting was disjointed and rambling, because I am elderly and suffer a debilitating CNS illness as further exposure severely affects my central and peripheral nervous system. At the same time my wife is ill with brain cancer and I am visiting her in hospital twice a day, and my illness is made worse to the exposure of high levels of microwave non-ionised radiation in the hospital and a number of phone towers that loom over the hospital. I can’t stay long and have to get home quickly to my safe unit and recover.My posting was asking for help and compassion not criticism.
I need a Netgear or any modem similar to the Netgear CG3100D that works over HFC, but has a "green phone jack" connection for my corded phone and no 5GHz transmitter installed into it. The SMART modem my server sent out with the technician had the "green phone jack" and all connected up and worked well, but the 5GHz transmitter couldn't be disabled.
Can’t you understand the seriousness of my health and label it pseudo-science, when I am calling out for help on a matter that has a bearing human health?
Can you help me instead of criticising and belittling me?
I cannot have any wireless in my home whatsoever.
Have read of the pseudo-science at this site, particularly US DIA (1976), as I was one of those military personnel affected: https://www.orsaa.org/research-papers.html
- antinodeMar 02, 2019Guru
> [...] my illness is made worse to the exposure of high levels of
> microwave non-ionised radiation [...]I doubt it, but I don't expect to see a double-blind test on this
hypothesis any time soon.> Can you help me instead of criticising and belittling me?
I tried. I suggested shielding. (Maxwell's laws are real science.)
- Aussie123Mar 03, 2019Aspirant
What a shame, we do have people like you around who can't help a person in need. All I am askling is information to find a safe Netgear modem, and you waste your time insulting and belittling me. What a shame---water off a duck's back.
Be blessed in your lack of concern and compassion.
