ashmak's avatar
ashmak
Tutor
Mar 20, 2023
CM 1100 does not show login window
My modem CM 1100 does not show login window at http://192.168.100.1
Is there any solution?
I am following these steps:
  1. Launch a web browser from a computer that is attached with an Ethernet cable to the cable modem or from a computer that is connected to a WiFi router that is attached with an Ethernet cable to the cable modem. - Done
  2. Enter http://192.168.100.1. into the address bar of your web browser.
  3. Click or tap Enter.
    A login window displays. - No login window displays?
  4. Enter the cable modem user name and password.
    Note: The user name is admin and the default password is password. The user name and password are case-sensitive.
    The BASIC Home page displays.
    Clear the cache on the web browser you are using.
    Try a different web browser than the one you are using.
    You using a Windows computer or iOS?
    • ashmak's avatar
      ashmak
      Tutor
      Kitsap
      I did that but it doesn't help.
       I used Safari and Chrome on my MacBook Pro. I also tried on my iPhone. For router, login window opens quickly at 192.168.1.1 but not for Modem.
      • FURRYe38's avatar
        What brand and model is the router connected to the CM modem?
        Power off the modem and disconnect the wifi router from the modem and connect 1 wired PC to WAN port#1. Power ON the modem, after it's ready can you connect to the modem at 192.168.100.1 at all?
