Tucson_Jim's avatar
Mar 07, 2023
CM 1100 no longer xFinity Compatible
The CM 1100 cable modem is no longer compatible to use with xFinity.
They can no longer see or talk to the modem. On their webpage they show INCOMPATIBLE BASED ON FILTERS. Customer service confirmed they cannot see nor talk to the modem.
Have no idea what this means nor how to resolve this.
Looks like time to buy another cable modem that IS on the xFinity list. May NOT be NetGear if this is not solvable.
Since xFinity cannot update the cable modem, is netgear now responsible to resolve this? the CM 1100 is still being sold as xFinity compatible. Not even sure how to update modem to resolve this if there is a solution.
  • FURRYe38's avatar
    The the CM has LAG support, base speed support is for 1Gb and in most cases home users don't use LAG. Even the WAN ports are only rated at 1Gb per port so technically, the CM1100 reaches this limit on a  single 1Gb line.
    We know the ISP recently split there speed tier last year, now 800Mpbs and 1.2Gb. Were seeing problems with some other modems that only support 1Gb on the WAN and LAN side and the ISP up'd the speed to 1.2Gb. The ISP has not certified these modems for 1.2Gb services. So this change is on the ISP side.
    One thing to try, have the ISP set your speed package at 800Mpbs.
    Another would be to test the CM1100 at a different location, friends or family that may have a different ISP service or speed tier and see if the modem responds differently there.
    Or find something that handles 1.2Gb or higher speeds. NG CM2000 series comes to mind since those have 2.5Gb WAN port.
