davids87's avatar
davids87
CM 1200 not connecting to internet
Power went out and my CM1200 cannot longer connect to the internet.
I just with the cable company, and they could not communicate with the device.
All the lights are on, but the Internet light (the globe) keeps on blinking green. Per the Netgear tech, I need reset and reprogram the router so that it can find the channel.
I connected my old router and my internet is working. How can I reset and program the router to fix this.
Thanks
  • plemans's avatar
    You connected your old router or modem?
    do you have other devices connected to the cm1200?
    • davids87's avatar
      davids87
      No, I connected my old modem just to test if the internet was working from the provider side, and it is. This old modem is connect to my wifi router.
      The CM1200 modem is now just connected to electricity
      • FURRYe38's avatar
        Did you connect your wifi router to the CM1200 modem after you go the modem associated with the ISP service first?
