ashguptak
Nov 18, 2019Aspirant
CM 600 Network Name unknown
I recently bought a Netgear CM600 cable modem router. Successfully setup the internet activation, however, I am not able to discover the Wifi Network name(SSID Name) to login. The bottom stickers on the Router have the MAC, Serial no and login credentials but not the Network name.
The CM600 is a modem only. There isn't a router and therefore is no wifi. You need to purchase a router seperate from modem.
- ashguptakAspirant
I checked with the Comcast operator and she said it is a compatible device for Wifi connection.
Its compatible with comcast service but its a modem only device. There is no router integrated to it. Netgear makes modem/router combo devices but the CM600 is not one of them.
https://www.lifewire.com/difference-between-modem-and-router-4159854
