llewis01
Feb 16, 2017Aspirant
CM 600
After installing my cm600 cable modem with my isp. It seems that I can not login to the modem. I have tried the ip address and it tell me that connection was reset. Does the isp lock out that option after it is install on their network?
Thanks
Figured out what the problem was. I always use firefox but that didn't work so I microsoft edge and that worked.
Thanks
- djc6Luminary
I've not heard of ISPs blocking access to http://192.168.100.1/ - what ISP do you have?
Have you tried turning it off/on and/or the reset button on back of modem?
- llewis01Aspirant
Thanks
