Jpierre2's avatar
Jpierre2
CM 600Modem keeps disconnecting
So my wifi has been going out and I tried to search up the problem and haven't found anything. Can anyone help me? This is what my event log says.
2021-02-11, 09:46:54Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:54Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:51Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:50Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:39Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:39Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:25Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:19Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
2021-02-11, 09:46:06Warning (5)MDD message timeout;CM-MAC=44:a5:6e:ba:41:78;CMTS-MAC=00:a2:89:d1:69:d3;CM-QOS=1.1;CM-VER=3.0;
