buckZor
Feb 15, 2017Guide
CM1000 - BendBroadband (Bend, Oregon)
Just a pre-purchase question, has anyone had success with the CM1000 Cable Modem in Bend, Oregon? BendBroadband is our provider, they are owned by TDS parent company. I called support and was assur...
buckZor
Feb 15, 2017Guide
That is definitely one of my concerns, I've heard that the .15 firmware revision is solving problems for some people. If my ISP doesn't push out the firmware how the heck do I get it onto my device? My understanding is that there is no end-user method of doing so..
vkdelta
Feb 16, 2017NETGEAR Employee Retired
there is no end user upgrade method for Cable devices.
ask your ISP if they will push. we are happy to provide them the signed image to push.
otherwise, PM me...
