buckZor
Feb 15, 2017Guide
CM1000 - BendBroadband (Bend, Oregon)
Just a pre-purchase question, has anyone had success with the CM1000 Cable Modem in Bend, Oregon? BendBroadband is our provider, they are owned by TDS parent company. I called support and was assur...
buckZor
Feb 16, 2017Guide
Wanted to follow-up. I've received my CM1000 from Amazon and have installed it. I did have to call Bend Broadband for their assistance provisioning and re-associating my Static IP (reserved address) to work with the new modem. I am noticing very nice latency results so far to the first hop BendBroadband router. 16 channels are bonding down (I used to have 4 with my old Arris WBM760A) and 2 channels bonded up.
Attached are screenshots of my "Cable Connection" details, does this look good to those of you who understand these values?
vkdelta
Feb 17, 2017NETGEAR Employee Retired
both DS and US values look good.
glad latency is good.
if you have contacts as BendBroadband, you can share with us and we can provide them new FW.
- buckZorFeb 17, 2017Guide
Do you recommend we do that, or if it is working fine should I just let it be on the v2.01.14?
- vkdeltaFeb 20, 2017NETGEAR Employee Retired
It depeonds on how bad RF can get on your plant. If it gets bad, you will see issues and 2.01.15 will resolve so that you dont have to manually reset the modem.
- buckZorJun 28, 2017Guide
I am having frequent problems now, fixed by rebooting the modem. I would really like a newer firmware for my modem, HOW do I do that, my broadband vendor does not know how to upgrade the firmware and tells me to talk to the modem vendor (you). Bend Broadband is my ISP, they are a subsidiary of TDS Telecom.
