buckZor
Feb 15, 2017Guide
CM1000 - BendBroadband (Bend, Oregon)
Just a pre-purchase question, has anyone had success with the CM1000 Cable Modem in Bend, Oregon? BendBroadband is our provider, they are owned by TDS parent company. I called support and was assur...
buckZor
Feb 17, 2017Guide
Do you recommend we do that, or if it is working fine should I just let it be on the v2.01.14?
vkdelta
Feb 20, 2017NETGEAR Employee Retired
It depeonds on how bad RF can get on your plant. If it gets bad, you will see issues and 2.01.15 will resolve so that you dont have to manually reset the modem.
- buckZorJun 28, 2017Guide
I am having frequent problems now, fixed by rebooting the modem. I would really like a newer firmware for my modem, HOW do I do that, my broadband vendor does not know how to upgrade the firmware and tells me to talk to the modem vendor (you). Bend Broadband is my ISP, they are a subsidiary of TDS Telecom.
- vkdeltaJul 07, 2017NETGEAR Employee Retired
unfortunately, their internal policy is to not support any retail modem upgrades. It is very unfortunate, but that is Bend-Broadbands policy. It applies to any retail device.
