dmulholland95
May 12, 2017Aspirant
CM1000 / MOCA 2.0
Is the CM1000 modem capable with the Actiontec 6200 moca adapter ? Also the Nighthawk X10 ?
dmulholland95
Currently the actiontec has the direct outside line , output feeds the modem. Ethernet is run from the actiontec to the router.
- William10aMay 12, 2017Master
If it is working it much be more then one way too connect the device.
