dmulholland95
May 12, 2017Aspirant
CM1000 / MOCA 2.0
Is the CM1000 modem capable with the Actiontec 6200 moca adapter ? Also the Nighthawk X10 ?
dmulholland95
Currently the actiontec has the direct outside line , output feeds the modem. Ethernet is run from the actiontec to the router.
William10a
May 12, 2017Master
If it is working it much be more then one way too connect the device.
