tbone3000
Feb 27, 2018Follower
CM1000 + nighthawk 65 loosing connectivity issue
i Just bought the cm1000 modum and Nighthawk 65 wifi unit. never had an issue before i got them.. ( internet provider is Comcast ) so my issue is that all is up and running smooth then every day and ...
DarrenM
Mar 05, 2018Sr. NETGEAR Moderator
When you lose internet have you tried to connect a ethernet cord directly to the CM1000 this If you still get a internet connection then you know its some issue with just the router and then we can troubleshoot more.
DarrenM
