Billytheoldman
Jun 23, 2022Follower
Cm1000 and nighthawk x4s. Loose connection to Internet requires a reset to factory default
This problem just started happening when I left my cm1000 modem unplugged for a while and plugged it back it. It could no longer find the network. I think I reset the x4s router and it came back. I can reset the cm1000 modem too and it comes back. Power off and on the modem or/and router won’t fix it. At first I thought a bit was messing with me because I didn’t realize that the cm1000 was a router too not just a modem. So I had left it’s password to the default on the cm1000. Which meant I was exposed. I change the password on the modem now so that is good. I’ve been running this hardware here for 3 years without a problem. I just updated the x4s router to the latest firmware after I started having problems. Any ideas?
1 Reply
The CM1000 is ONLY a modem. There is no built in router.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.What Firmware version is currently loaded on the modem and router?
Try connecting 1 wired PC to the modem and power cycle it. After the modem comes to ready can you get internet services thru the modem on the PC?Be sure your using good quality LAN cable between the modem and router. CAT6 is recommended.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
